Revit Architecture
Distinguished Contributor
RNDPIS
Message 1 of 5 (517 Views)
Reference Plane Elevation
517 Views, 4 Replies
04-25-2012 10:06 PM
When we draw a reference plane in a project in the Level 1 (0'  0" Elevation) then the  reference plane elevation shows  4’ 0” in the Specify Shared Coordinates Tab.  Why the elevation of reference plane shows the 4’ 0” height?  Is it default elevation for reference plane? See the attached jpg .Please help in this issue. Thanks in advance.
Alfredo_Medina
Message 2 of 5 (502 Views)
Re: Reference Plane Elevation
04-26-2012 07:06 AM in reply to: RNDPIS
Reference planes do not have an elevation value. So, in this case, those values do not refer to the reference plane. Most likely, the project based point has been modified, "moving" the whole project 4 feet up. To correct it, select the project base point in a site plan view, and change its "z" value to 0.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
RNDPIS
Message 3 of 5 (483 Views)
04-26-2012 09:56 PM in reply to: Alfredo_Medina
Thanks for your clarification.
But we can't move the project based point. We have studied in this topic and finally come to the solutions that it's elevation shows because of View Range Setting (Level 1: Default Cut Plane 4' & Site :Default Cut Plane 200')
I have attached a jpg.
parveen.revit
Message 4 of 5 (473 Views)
04-26-2012 10:25 PM in reply to: RNDPIS
by default all plans' cut plane is set to 4'-0" or 1200mm in Revit Architecture.
Revit Structure has different settings (1'-0") as by default cut plane.
If you draw a wall (or other model elements), these will be drawn in reference to respective levels since their 'Base Constraint' is set as Level Name and Base Offset is 0'-0".
In case of rerence plane, these parameters (base constraint and base offset) are not available, so reference plane shared parameter properties shows the value as 4'-0" (cut plane).
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Alfredo_Medina
Message 5 of 5 (458 Views)
04-27-2012 04:41 AM in reply to: parveen.revit
  • Reference planes do not have an elevation value.
  • View range does not have anything to do with the elevation value of an object.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
