I need to add "Level" into my Cable Tray schedule; we need to sort the cable trays lengths by floor level. However, "Level" is not listed as one of the available fields, even though level information (show up as "Reference Level) is one of the constraints in the cable tray model.
Please help.
Solved by Alfredo_Medina. Go to Solution.
In Revit, for some reason, there are many cases in which instance parameters that are visible in the Properties dialog are not available in the schedules. In this case, use the "Add parameter" button of the schedule, to create a new project parameter for cable trays. Then, in the project, maybe from a section or elevation view, you need to select cable tray elements and enter the "level" identification, manually, in the new parameter.
Thank for the answer @Alfredo_Medina, Please can anyone suggest easy method instead of this ?
Well basically you are obliged to use a shared parameter, but you could automate the step of filling in the right level with Dynamo.
