Recessed Lighting Fixture
1 REPLY 1
RogerCusson
1361 Views, 1 Reply
Hi All, I trying to create a family for a wall based recessed lighting fixture. I would like the fixture to be recessed but not to disrupt the non placement side of the wall. 1/ I've tried to create an opening but this goes through the entire wall, leaving me to place an extrusion on the backside of the wall. 2/ I've also tried to create a void form but this does not seem to affect the wall host. Any additional ideas? Thanks in Advance, cheers Roger C.
1 REPLY 1
ryan.duell
in reply to: RogerCusson
You would need to cut an opening in the wall with a void to prevent the light source from being blocked.  I had a similar post at the link below:
http://revitclinic.typepad.com/my_weblog/2009/12/recessed-can-light-fixtures-not-casting-light.html
For this, you should be able to create a simple wall based family containing a void.  You could additionally add parameters to control the void size.  Simple example:
Video Example: http://screencast.com/t/SvGtu3zeocT
I hope this helps!
Thank you,
Ryan Duell
Tags (3)
