I just discovered the rafter framing extensions for revit.
It is verry handy but at places where there is a hip/valley the rafters are shown until the hip/valley. at all the other places (where there are ridgtes) they are cut at the place where the roof is cut.
I found another thread where they say to change the visibility settings of the rafter family what I already did before but it does not change annything in my floorplan.
Does annyone else has annother sollution for my problem?
Thank you for visisnt our forum!
Can you please post an image of issue along with a sample project?
Here you have 3 pdf files in the floor plan I made with a red mark the 2 who show the wrong lines and in green you can see the correct lines I would like to see on the red ones.
in the 3D structure file you can see the same rafters in red and green
It seems like it could be an issue with the cut plane.
I tried recreating the issue onmy end but I was not able to.
Can you please attach the roof file and the steps you took to create the rafters?
Thanks.
