Dan
Our supplier is Karel Cad, I was trying to think of the guys name I was
talking to about it but just cant remember. I would suggest give your
supplier a call and ask them if they have heard of this problem. Karel Cad
in Aust release a news letter each month & in there last news letter it had
this problem stated in it. I didnt recieve this one personaly but will
contact Karel Cad today and ask to have it emailed to me then I will provide
a scanned copy of it on here for all to view.
"D" wrote in message
news:5366929@discussion.autodesk.com...
you're in Aust?
who is the supplier?, I assume it will be the same as ours (there aren't
that many...) I would like to get a handle on this before we get into some
serious trouble.....
My main issue is that I can't work out what Graphic settings I need to make
9.1 stop jumping around in a 3D orbit!
I've tried all combinations of OpenGl and Overlay Planes and still I get
jumpy views / beam lines showing through my floor / not being able to select
my object at the point my cursor is at! all graphic driven I assume....
but it was all working so well yesterday!!
(arrgghh!)
Cheers,
Dan
"Chris Kendall" wrote in message
news:5366866@discussion.autodesk.com...
"david" wrote in message
news:5366890@discussion.autodesk.com...
Revit files are huge and complex when compared to almost any other software.
Revit files are vulnerable to corruption when saving regardless of the
version. If you have other programs running when saving, or your RAM is not
operating correctly, or you have a bug or virus, or you have operating
software problems (problems with windows? surely you jest), even driver
compatibility issues with insignificant peripherals....Revit will act like a
Canary in a coal mine. Whenever I've had corruption problems with Revit
files...it actually never turned out to be a Revit issue.
That being said....perhaps 9.1 does have a problem.
My supplier is adiment that it is a bug to do just with 9.1. Theres really
no reason for him to lie about it, and the fact it only started happening
once we upgraded shows it is only to do with 9.1.
