REVIT and RAM Steel
2 REPLIES 2
537 Views, 2 Replies
REVIT and RAM Steel
Hello;
I am a structural designer and am looking into to possibility of converting several seats of AutoCAD to REVIT. The main factor is, how well does REVIT handle models from RAM Steel. Has anyone used the two programs and inserted RAM Steel models into REVIT. If so, how was it? Any problems? Would you recommend it? Any comments would be appreciated
Thanks.
2 REPLIES 2
You need to contact Nicolas Magnon at Autodesk Revit. He is the Product Manager for the Structural aspect of Revit. We have heard that Revit will soon have a full structural package, and will interface with many analysis programs, including those such as RamSteel. "wmerrill" wrote in message news:31076226.1100011691711.JavaMail.jive@jiveforum1.autodesk.com... > Hello; > I am a structural designer and am looking into to possibility of converting several seats of AutoCAD to REVIT. The main factor is, how well does REVIT handle models from RAM Steel. Has anyone used the two programs and inserted RAM Steel models into REVIT. If so, how was it? Any problems? Would you recommend it? Any comments would be appreciated > Thanks.
Thanks! I have contacted Nicolas Magnon at Autodesk Revit, and am awaiting his reply.
