I have been using revit for many versions, recently had a try on revit2013. I found out that the ribbon menu/icon didn't update by itself when I selected a face of a mass. I have to manually refresh the ribbon bar (minimize/unfold) by double click it or click the tiny triangle to make the associated icons (e.g.. The divide surface button) appear. When I finish the editing of massing and quit the mass mode, the form element menu still left in the ribbon unless I manually refresh it again.
This is most likely a video card issue. Try disabling hardware acceleration (big R --> Options --> Graphics tab --> Uncheck "Hardware Acceleration"). If that fixes it, then you'll probably have to get a new video card that works for Revit, otherwise you won't have access to some of the nice visualization/graphics tools (ray trace, ambient shadows, etc.).
The graphics features should now work with hardware acceleration on or off now. When hardware acceleration is turned off in 2013 the WARP (Windows OS graphics system) graphics system should take over and allow those features to still work (with some performance impact).
Good to know, Jeff, thank you. With that said, how does the hardware acceleration contribute?
I think overall the performance is going to be better with a certified graphics card and hardware accelleration turned on, but the use of WARP lets a wider range of users have the same graphic experience.
Hi Ross, I had nvidia 8800 with my pc for few years and it works fine with Revit2011 and Revit2012, and I try to turn off the Hardware Acceleration function and restart the revit the Ribbon issue persists, it also happens with my MBP2011. I guess revit 2013 is quite different when dealing the graphic hard problem
PLEAAASE someone give a direction. I'd reinstalled Revit and the problem stills.
I wanted to check in and confirm if this issue was still occurring? I had a few items to confirm:
Using the Windows Registry editor [Start > REGEDIT], right-click and rename the following registry folders (Panels_backup for example):
HKEY_CURRENT_USER\Software\Autodesk\Revit\{Revit Product Name} 2013\Components\Panels
HKEY_CURRENT_USER\Software\Autodesk\Revit\{Revit Product Name} 2013\Components\Dialogs
Then launch Revit 2013 and see if the issue persists. Please let me know if any of these items change the behavior.
Adding a post on this issue onto this thread below:
