I have a considerably long building that I'm cutting with a section leader.
I'd prefer to split one section into two images and stack them vertically (one over the other) on the same Sheet to be printed.
This appears to be an impossible feat in Revit.
Any recommendations are helpful. Thank you.
Only alternative is to display this long section at a lesser scale to fit onto one single page.
Solved by gustavomello. Go to Solution.
Use Scope Box:
Your Name
In step 2 i usually use "duplicate as a dependent" and create 2 copies of the section so i end with the complete section view and two partial section views. This way any change i made to annotations in the main section view is reflected over the other two.
Gustavo
