Revit Architecture
raangle
Message 1 of 5 (360 Views)
RB Link Error issue
360 Views, 4 Replies
08-30-2012 01:59 PM
As an Architect I have been more used to Revit on the Project and Design side than the database side.  My current role has changed that a bit and I am somewhat in a bubble with Revit sometimes within this company and most of my other contacts are on the Project and Design side and can’t help either.
As I am new to databases and ODBC side, when anything goes wrong I am lost.  I have an error message in Revit and have attached both the Log file and Error Report for reference.  Can’t get the ODBC to work on two projects I am working on, it creates the Database file fine but will not sync the data to it, that is when I get an error.
Product Support
Lance.Coffey
Message 2 of 5 (322 Views)
Re: RB Link Error issue
09-06-2012 01:55 PM in reply to: raangle
I did a search in the journal for "----Warning----", and found 48 lines like the following:
[----Warning----] Parameter changed from [Extensions.Extensions] to [ExtensionsExtensions] and it will be ignored when importing
[----Warning----] Parameter changed from [Extensions.Buffer6] to [ExtensionsBuffer6] and it will be ignored when importing
[----Warning----] Parameter changed from [Extensions.Buffer8] to [ExtensionsBuffer8] and it will be ignored when importing
It looks like the parameter names are being changed when sent through the ODBC connection (I looked online, and it doesn't look like it is a good practice to use periods in database names).
Lance Coffey
raangle
Message 3 of 5 (292 Views)
09-10-2012 10:38 AM in reply to: raangle
Revit and or the ODBC export are doing that, I have done nothing to the database other than export via RB Link and ODBC from Revit.  It does actually create the database, its just empty and does not sync the data from Revit to the database.
Product Support
Lance.Coffey
Message 4 of 5 (279 Views)
09-11-2012 02:45 PM in reply to: raangle
Does this issue occur if you use one of the sample projects (C:\Program Files\Autodesk\{Revit version}\Program\Samples)?
Lance Coffey
raangle
Message 5 of 5 (247 Views)
09-18-2012 03:07 PM in reply to: Lance.Coffey
have been swamped with other work, will look into this sometime this week.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
