Revit Architecture
jkkagalkar
Message 1 of 2 (137 Views)
Qunatity take off
137 Views, 1 Replies
09-12-2013 09:55 PM
I need to get the details from the quantity take off from Revit ARchitecture like:
how many bricks are there in wall?
how much cement bags are used in wall?
how much steel is used for columns
Thanks in advance
*Expert Elite*
LisaDrago
Message 2 of 2 (99 Views)
Re: Quantity take off
09-13-2013 06:07 AM in reply to: jkkagalkar
Hello and Welcome to the Discussion!
What you are looking for seems a bit more detailed then what Revit does out of the box...
The steel for the columns - yes you can get that from a material takeoff.
As for how MANY bricks.... Well you can get the area of the wall - and if you know the area of one brick - you could do a formula and run the calculation.. But I would only take it as a rough estimate.
Not sure on the bags of cement... Unless you can think of a way to create a formula... That would be the only way - and again I would only use it as a rough estimate...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Announcements
Need installation help?
