This might be a easy way to print all your sheet into one PDF.
To create multiple pages of dwg sheets in one PDF:
1. Go to Start menu > program files > software995 > pdfedit995
2. In this software window,
a. In the combine/extract tab, select combine pdf files
b. In the autolaunch tab, remove automatically display PDF after printing
c. In the auto-name tab. select option 2 (automatically name doc) (you could change the location of the file, if you wish)
d. That’s it. When you print from Revit, PDF995 keeps adding every sheet on top of the same file name.
To create multiple PDF files with separate dwg sheets:
Use the Burstpdf.exe software that came with signature995/pdf995. It is usually located at: “C:\pdf995\res\utilities” I cut and paste from the PDF995 help file:
“This utility (BurstPDF.exe) will break a PDF into several smaller PDFs of n pages. Paths must be in quotes. The "##" will be replaced by the document number. The final number specifies the pages per new PDF.
Example:
burstpdf.exe "c:\input.pdf" "c:\output##.pdf" 1
BurstPDF requires that Signature995 and the Standard Encryption Module v1.5 or later are installed. Both are free and may be downloaded from www.signature995.com.”
I hope this helps.
nicholas.
nicholas iyadurai
www.nichitecture.com
