Revit Architecture
*Expert Elite*
Message 1 of 3 (157 Views)
Accepted Solution
Publish DWF Local?
157 Views, 2 Replies
12-11-2012 09:49 AM
Is there any way to publish a revit project to a locally stored dwf file?  I want my students to be able to submit dwf files for grading without setting up buzzsaw accounts.
Seems strange that there is no obvious solution in the ribbon.  Are we relegated to printing to PDF?
Active Contributor
Message 2 of 3 (137 Views)
Re: Publish DWF Local?
12-12-2012 10:37 AM in reply to: dbroad
You can "Export" to DWF/DWFx from the Application pull-down.
*Expert Elite*
Message 3 of 3 (131 Views)
12-12-2012 10:42 AM in reply to: brettgatti
Thanks.  Coming from an AutoCAD background, I was puzzled as to why all the publish options were to buzzsaw.  Publishing must have a different connotation in Revit.  The Export option should work fine.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
