Publish DWF Local?
2 REPLIES 2
dbroad
318 Views, 2 Replies
Publish DWF Local?
Is there any way to publish a revit project to a locally stored dwf file?  I want my students to be able to submit dwf files for grading without setting up buzzsaw accounts.
Seems strange that there is no obvious solution in the ribbon.  Are we relegated to printing to PDF?
Architect, Registered NC, VA, SC, & GA.
2 REPLIES 2
brettgatti
in reply to: dbroad
You can "Export" to DWF/DWFx from the Application pull-down.
dbroad
in reply to: brettgatti
Thanks.  Coming from an AutoCAD background, I was puzzled as to why all the publish options were to buzzsaw.  Publishing must have a different connotation in Revit.  The Export option should work fine.
