Properties palette has changed and I can't get it back to normal.
2 REPLIES 2
922 Views, 2 Replies
When I open a project or family file (new or old) the properties palette is not the one I am used to seeing. Usually one can view sheets, 3D views, and elevations in a project file and (while I have located some of these options in the tool bar) they are not located conveniently on the properties palette as usual. When I open a family file, I can usually go to different elevations and create extrusions/model from different views. There is currently no option for viewing different elevations and when I go to toggle in a 3D view I can't go back to the reference plan (the only view I can model in).
Attached are images of what I currently see as my properties palette. If there is a way to get the normal one back, please help!
2 REPLIES 2
LisaDrago
Hello and Welcome to the Discussion!
Your Project Browser has been closed. It is a second dialog box usually with the Properties Pallete.
If you go to the View Tab> Windows pallete> User Interface pull down - click the check box next to Project Browser. This will turn it back on.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Hooray! Many thanks!
