Project Location points from Google Earth
3 REPLIES 3
Stephm419
442 Views, 3 Replies
I need to get a real location for a project in Manhattan, New York.
Does Revit have any tools to locate it.
Or are there any plugins?
3 REPLIES 3
LisaDrago
in reply to: Stephm419
Revit does have project location available... See image attached. It has the exact latitude and longitude available.
Or is there something more you are looking for?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Stephm419
The actual point I need is the corner of a property line.
Is that possible?
LisaDrago
Do you have all the surveyor information?
You should be able to locate that exact point. - Unless I am missing something...
LD
