I am a programmer with the Center for Research Computing at Notre Dame. I need to programmatically export a drawing in RevIt to gbXML. I am able to do this successfully, however, the "Export Complexity" is set to "Simple", which discards some data that is vital our analysis process. When exporting manually, we set this property to "Complex with Mullions and Shading Surfaces" in the export dialog. Is there a way to set this property of the export process when exporting through the API? Everything I've read seems to indicate that it is not possible. For reference, we are using RevIt 2014.
Thanks in advance,
Scott Szakonyi
Research Programmer
University of Notre Dame
