Problem with text - vertical rotation
1 REPLY 1
milaszka
363 Views, 1 Reply
Hi there. I need to have vertical lines in my title block but when I rotate text it is rotating in that way that I  read it from the bottom to the top where as it needs to be orinetated to read from the top to the bottom........can anyone help please?
1 REPLY 1
CoreyDaun
in reply to: milaszka
If I am understanding this correctly, you should be able to select the Text and disable the option "Keep Readable" under its Properties.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
