Problem with missing things
1 REPLY 1
213 Views, 1 Reply
I just installed Revit Architecture and I notice that there are many things missing. For example,there are no wall and floor  types except for one basic, there are no site elevations at the beginning and there is just one floor plan.  Also, I can't see any doors or windows. It says that no door/windows families are loaded. (You can see the problems on the attached pictures.)
I tried to uninstall the program and then install it again but nothing changed.
Can anyone tell me how I load families and if I can make all this things appear?
Thank you in advance!
1 REPLY 1
AJA14
Hi. There is no problem with the software itself, it is just a matter of missing templates, families, ...
Therefore, you could go ahead and download these from autodesk and place them in the correct location.
Just two things for you to remember.
1- Walls are system families, therefore there are no families you could load, but the template you start with will have some built in types. Therefore, to create new floors in case you start from an empty template is to click edit type, duplicate, rename, edit structure, and create any new type you would like.(Same thing applies to floors)
2- Column, doors, windows, ... are loadable families, that is why you get asked to load them, so if you click yes and find none, it means they are missing and you need to download them and place them in their corresponding folders.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
