Problem with Spell Check
3 REPLIES 3
595 Views, 3 Replies
Hey Guys I had the following problem, I'm trying to finish a project on revit 2013, but for some odd reason, the spell check window pops up every seccond telling me that had finished doing the grammar correction
With this problem I can't work on my project and is really annoying, I hope to see if some of you know the solution of this problem
3 REPLIES 3
rkitect28
Do you by chance have a frequently used keyboard shortcut set to perform the "Spell Check" command? I believe it is F7 by default. Or is it happening when you are idle?
No, I don't use shortcuts on Revit and this happens while I'm idle or trying to do an structure like a desk
bellesmum
Is it only in this project?
Can you post a picture of the dialog?
Lynn Poliquin
Senior QA Analyst
Autodesk, Inc.
