Revit Architecture
New Member
t_deferme
Message 1 of 2 (356 Views)
Problem: visibility of a beam in plan view
356 Views, 1 Replies
07-15-2011 02:08 AM
If i draw a beam in plan view en define the height, the beam disepare. Is there a posibility that the beam is in place and you can see a dash dot line and two dashed lines in plan view?
thx
Message 2 of 2 (327 Views)
Re: Problem: visibility of a beam in plan view
07-17-2011 02:18 PM in reply to: t_deferme
Most likely the beam level is above the view cut plane level. If you put in a plan region where the beam is located ( View tab / plan views / plan region ) and set this cut level to be through the beam, you can then see the beam.  You can then use the linework tool to get a dash dot line or however you would like it to display.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
