Problem in the End Wall Layer Wrap
0 REPLIES 0
Message 1 of 1
GHASEM_ARIYANI
281 Views, 0 Replies
I have a problem with the end walls And to this day I could not to fix the problem.
For example, I've created a wall with the following specifications:
Notice the layers in the END walls,Always one of the layers (external or internal) is located on the other side.(The picture the note underneath)
In view of the 3D  Appear correctly, But in the 2D plan is wrong.
Do we can adjust the in 2D view layers Like the Miter???
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
0 REPLIES 0
