Revit Architecture
Message 11 of 14 (146 Views)
Re: Problem copying fixture in certain types of ceiling.
03-02-2014 03:42 PM in reply to: Alfredo_Medina
Adding the surface pattern fixed it and it is a workaround.  Did you add it or it comes with the OOTB ceiling type?  Thanks.
Alfredo_Medina
Message 12 of 14 (141 Views)
03-02-2014 04:10 PM in reply to: ToanDN
I added the surface pattern to the properties of the ceiling.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Message 13 of 14 (133 Views)
03-02-2014 05:39 PM in reply to: ToanDN
Thanks. That is also my workaround. I had to edit the ceiling types, add some surface pattern, and change its color to white. It's a fairly easy fix once you know the root of the problem. Still, I stand by my statement that AutoDesk should be fixing it permanently for non patterned ceiling types.
Alfredo_Medina
Message 14 of 14 (123 Views)
03-02-2014 10:04 PM in reply to: ToanDN
I am not sure if the presence of the pattern on the ceiling is the reason. This is a strange case.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
