Revit Architecture
Message 1 of 14 (318 Views)
Problem copying fixture in certain types of ceiling.
318 Views, 13 Replies
02-27-2014 11:18 PM
Revit Architecture 2013/2014
I cannot copy any ceiling hosted fixture in any types of ceiling other than the ACT types.  It always gives the infamous "Can't cut instance(s) of [fixture] out of its host." then places the copied instance on the same spot as the original, at best.  Create similar and mirror still work, though.
Upon study, I found the lack of a surface pattern on the finish material is most likely the culprit.  Hence, I do have some workarounds to oversome this problem based on that finding.
Does anyone else have this problem?  Is so, is there any official fix?
-Toan.
Distinguished Contributor
subhra_civil
Message 2 of 14 (307 Views)
Re: Problem copying fixture in certain types of ceiling.
02-28-2014 12:00 AM in reply to: ToanDN
Can you send your file pls????
Thanks & regards,
Subhradeep Sen
India
Kolkata
Message 3 of 14 (273 Views)
02-28-2014 12:42 PM in reply to: ToanDN
I don't have Revit right now but you can try with any out of the box GWB or Generic ceilings.
Alfredo_Medina
Message 4 of 14 (266 Views)
02-28-2014 12:50 PM in reply to: ToanDN
It sounds as if the family is set to automatically cut the ceiling, and when you apply it to a ceiling that does have thickness, it works, but if you try to put in a ceiling whose type is "plain" it doesn't work because that type doesn't have thickness.
More specific information about the family or ceiling types involved, would help.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Message 5 of 14 (250 Views)
02-28-2014 09:14 PM in reply to: Alfredo_Medina
Thanks for answering but I don't think your assumption is accurate.  The GWB ceiling has thickness as well.  As I already mentioned, placing component directly, mirroring, and creating similar work normally.  Only the copy command does not work.
Please see the attached.  Everything is OOTB.
Alfredo_Medina
Message 6 of 14 (217 Views)
03-02-2014 08:41 AM in reply to: ToanDN
It is strange, but those ceiling entities in this project are corrupted. I tested all other possible reasons, and could not find anything wrong. But for some reason those ceilings are not being recognized as a valid host for an architectural supply diffuser family. I deleted the ceilings and made them again, without doing any other changes, and now all the fixtures can be placed and copied without any problem.
Message 7 of 14 (205 Views)
03-02-2014 02:04 PM in reply to: Alfredo_Medina
I could not replicate how you fix it.  Would you post the file?  Thanks.
Alfredo_Medina
Message 8 of 14 (201 Views)
03-02-2014 02:06 PM in reply to: ToanDN
I simply deleted the ceilings and made them again with automatic sketch, then I put the air terminals again, and everything worked as normal. Sorry I didn't save it. Please try that and let us know if that works.
Message 9 of 14 (196 Views)
03-02-2014 02:19 PM in reply to: Alfredo_Medina
That was exactly what I have just tried. It did not work for any ceiling hosted components, not just the diffuser. Practically, it is not a huge problem for me because I have workarounds for it, and/or use other creation methods. But for other folks in my office, who are very accustomed to AutoCAD operation, it annoys them very much.
Alfredo_Medina
Message 10 of 14 (190 Views)
03-02-2014 03:17 PM in reply to: ToanDN
Attached is a file that I created from scratch. Please try to copy the fixtures in the gypsum board ceiling.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
