Problem With Bearings
3 REPLIES 3
346 Views, 3 Replies
Hi Guys,
I have just completed an entire house with the site plan and everything. I just found out however that the property is facing in the wrong direction. Im trying the go to site plan, highlight everything and rotate it so all of it is facing in the right direction but it wont let me.
If you could help, that would be great,
Mitch.
3 REPLIES 3
Is there perhaps a way that i can rotate the orientation of the sun in solar study?
constantin.stroescu
Not sure I understand you well...the title and the text seems to speak about different things...
As I understood you want to orientate the site to True North. If this is what you want you have to do it in two steps:
  1. in Properties > Graphics > Orientation > swap to True North
  2. Manage >Position >Rotate True North - proceed with rotation to the desired position
If step 1 is not made and you try directly step 2 you will be asked to do step 1
Constantin Stroescu
in reply to: constantin.stroescu
Haha sorry, it worked. Thanks heaps
