Hi Guys,
I have just completed an entire house with the site plan and everything. I just found out however that the property is facing in the wrong direction. Im trying the go to site plan, highlight everything and rotate it so all of it is facing in the right direction but it wont let me.
If you could help, that would be great,
Mitch.
Solved by constantin.stroescu. Go to Solution.
Not sure I understand you well...the title and the text seems to speak about different things...
As I understood you want to orientate the site to True North. If this is what you want you have to do it in two steps:
If step 1 is not made and you try directly step 2 you will be asked to do step 1
Your Name
