I am having trouble installing a previous version of 2011 Revit Architecture and Structure after sucessfully downloading and installing 2011 Revit MEP.
After the download when I try to install I get error warnings of corrupt files saying I should download fresh copy.
When I try to install I get these error codes:
CRC failed in Revit Setup\ Revit Architecture\ x64.cab
CRC failed in Revit Setup\ Architecture\ x86.cab
I have a newer version of Windows 7, when I installed the 2011 Revit MEP in compatibility with older version of window xp service pack 2. The MEP version actuallys says 2011 Revit B MEP, I do not know what the B means but do not see the same thing in the Architeture and Structure Downloads.
I downloaded the Revit Architecture a second time with the same problem.
Should I request a CD through the subsciption center? Not sure how to move forward on this.
You will not be able to install revit architecture after installing MEP you will have to go the other way Architecture first and then MEP.
