I am curious if it possible to edit the infromation that displays when you hover over an object during preselection. Attached is a clearer description of what i would like to adjust. I would like to add the pipe size to this infromation.
Hey
You may be able to do this if you have knowledge of the Revit API but there are no options to change the hover over info. The reason it is there is simply to let you know what you would select if you clicked, giving you the Category - Family - Type.
If you put the pipe size in the type name it would show up when you hover over it, apart from that, this cannot be edited.
Hope this helps
