Revit Architecture
Valued Mentor
gh_ar
Message 1 of 4 (159 Views)
Polygon Wall Problem
159 Views, 3 Replies
09-14-2013 09:51 AM
hi
Why when Drawing wall With Tool Polygon Surface External Wall Inside the polygon Placed.
Is there a way There are The default In the external Be.
Not pressing Space While drawing.
Because the radius is important for me.
thanks.
*Expert Elite*
constantin.stroescu
Message 2 of 4 (140 Views)
Re: Polygon Wall Problem
09-14-2013 11:59 AM in reply to: gh_ar
It seems that there is indeed a problem with the wall orientation...at least I didn't find the solution...
Personally, I do not find it very frustrating because I prefer to make first a geometric sketch that allows me a more accurate approach :
  1. First , I draw a polygon : Architecture > Model Line > Inscribed (or Circumscribed ) Polygon .
  2. Then: Architecture > Wall > Pick Lines....use TAB in order to select the entire polygon and hovering the mouse control how the wall is placed  (image 1 and 2) on the polygon edges....
But , as I said, this is my personal approach....
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 3 of 4 (138 Views)
09-14-2013 12:03 PM in reply to: constantin.stroescu
hi
Namely I draw One Polygon Should be Of several Tools I use.
No - I do not accept
*Expert Elite*
Alfredo_Medina
Message 4 of 4 (116 Views)
09-14-2013 02:15 PM in reply to: gh_ar
Yes, I agree with Constantin. I would draw a polygon with lines, first, then I would draw walls following that polygon as a guide. Not a big deal.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
