Hello, I have some trouble figuring out the best way in which I would import Recap file with the point cloud into the Revit. Architects that would use it would want to put the point cloud to 0 and I just want to make sure that if there are some later scans on the same area i can bring them into the revit again and that they will fit with the existing ones. Thank you and I hope that the question makes sence .
See this video: https://www.youtube.com/watch?v=JWZnC5vNQjY
Open the point cloud in ReCap > save it out > open Revit > Insert Point Cloud and chose the file you just saved in ReCap. If the file updates I'm assuming that imporing in the same place.
Thanks for posting.
