I am trying to print an elevation view of a kitchen in color. I put my views in a sheet and the kitchen view is set as Realistic as this is the nicest setting. The ceiling is white, but it prints as purple. I think its a shadow problem...? The other colors seem to be pretty accurate. I have all print settings set to the highest quality too. Are there any settings that I can adjust?
I troubleshooted the plotter and there are no problems with it. I am working with Revit 2014. I have an HP Designjet 800.
Thanks!
A. May I suggest that you save the rendered viewport as an image file in your project and use that in lieu of live rendering port?
B. May I also suggest that you make the sheet a .pdf and then plot it from the .pdf file?
Those Designjet 800's are a reliable work horse but are not modern enough for images directly from Revit.
Good Luck.
Thanks, tried your advise. Didn't quite work but good to know how to do that. Installed updted driver, seemed to help alittle. I think it might just be the shading in the room. Thanks again.
