Ploblem with material take off
7 REPLIES 7
Message 1 of 8
nikoue
2484 Views, 7 Replies
I' m trying the last few days Revit Architecture to see if it meets the needs of my.
The main think i want from a program like Revit is to have material take off.
So i spending a lot of hours trying to model the building that i am going to construct.
So i have some problems that i can't resolve.
First of all columns.I try a lot of things to model columns. First i use architectural columns  with walls, and then i put concrete structural columns and join them with the architectural columns and with walls. I seems fine but when i make a material take off the results was not correct. Now i m trying to use structural columns and join them with walls and then place interior a thin wall with finish material.
The second problems is beams. Again i use concrete beams and i cant find how to apply finish material. Its not so easy to place and coordinate correct wall for finish material .
The last think was slabs. If i apply a finish material  bottom of the slab ,and the wall with the same finish material attach to slab, I see in section than the connection is correct. But again in material take off nothing change in the values of finish material before and after the wall attach to it. I use finish material (5) in bottom of the slab and in the wall.
Also the concrete beam doesn't join correctly with the slab. The finish material of the slab stays between beam and slab after the join.
So with all that i don't have a correct material take off.
I m doing something wrong or there is no way to have a correct material take off?
Thank you and sorry for my bad English
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
7 REPLIES 7
Message 2 of 8
Lance.Coffey
in reply to: nikoue
It doesn't look like there is a built in option to specify a finish material for beams. I found the following AUGI post regarding applying a finish material to concrete beams:
Concrete beams: How to apply a finish material?
http://forums.augi.com/showthread.php?106108-Concrete-beams-How-to-apply-a-finish-material
I found the following note in the WikiHelp topic for Material Takeoff Schedules that may relate to the differences you are seeing when joining elements:
"When Revit computes the volume of materials for individual layers within a wall, some approximations are made to maintain performance. Minor discrepancies might appear between the volumes visible in the model and those shown in the material takeoff schedule. These discrepancies tend to occur when you add a sweep or a reveal to a wall, or under certain join conditions."
Here is the link to the help topic:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1557-Schedule1557...
Lance Coffey
Technical Support Specialist
Message 3 of 8
nikoue
in reply to: nikoue
So if i understand correct with revit i cannot have a presice material take off
Message 4 of 8
nikoue
in reply to: nikoue
No one have problems with material take off?
Or no one use material take off.
It s a huge problem what i describe.
If i cannot use join command, then its to difficult and time consuming to model with revit
Message 5 of 8
nikoue
in reply to: nikoue
please help
Message 6 of 8
Alfredo_Medina
in reply to: nikoue
I remember seeing some posts in forums, showing very detailed issues in which the use of the Join Geometry tool was causing incorrect results in quantities and material take-off schedules. So, I can say that this issue that you are experimenting is what programmers call "a known issue".
I think that designers and estimators should use 2 different styles of modeling. Designers need to use Join Geometry to obtain a correct graphical representation in their views, especially in sections. Estimators need to model the building (or modify an existing one) for the main purpose of obtaining accurate quantities in schedules, without caring for the graphical views. Therefore, in this style, the estimator should avoid joining objects, to avoid these known issues.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 7 of 8
in reply to: Alfredo_Medina
I see you are posting your company logo in the signature
area, that's great. Apparently now that Autodesk employees
are posting their logo, it's only fair that we all be allowed to.
Message 8 of 8
nikoue
I agree that this is a solution but in some cases the coordination is very difficult. And also you must need to model twice. Is there any possibility Autodesk solve that issue. For how many years it will be a known issue? And has anyone an answer about of the percentage of the incorrect results?
