Quite simple what I want to acheive in ACA but not in revit. I want a line elevation view from file A (with shadows if possible) to insert into another file (B) sheet (so it shows another option variant without the complexity of setting up phases to show that option in file B. I can insert from file a render - managed that successfully but I dont want full renders as the the recipient (a planning authority) will plot from a pdf non-colour.
Is there any way of rendering so that the result is mostly line with a bit of half tone? I do elevations within a project this way by setting up a 3D aligned to elevation then sort out what I want shaded / colour / line by graphic overrrides.
Any ideas?
Is this an ACA question or a Revit question. If Revit I would export images or screen shots and then import into another model. Either of these will be the fastest way to achieve what you want. Thanks for posting.
