You could use a specialized 3D view which will show what you want to be able to
apply molding:
- Hit the 3D icon in the QAT to create a default 3D view.
- R/C on the ViewCube > Orient to View > Floor Plans > [Select the plan view you
want to deal with). That creates a 3D view that has the same cut plane and
visibility as the floor plan, with the section box.
- Use the ViewCube to re-orient the view to a 3D view (e.g., r/click the
ViewCube, Orient to a Direction > Southwest Isometric)
- R/C on select elements that you may want to hide > Hide in view, such as
floors, trees, site, etc.
- Click the section box to enable the grips to resize it as needed.
- Use VG to edit the view properties, and set your ceiling category to be
Transparent. You should still see the outline of the ceiling against the wall.
Matt
matt@stachoni.com
On Tue, 29 Dec 2009 17:06:50 -0800, bea09 <> wrote:
>I don't know how to place crown moulding on built model multi-level interior wall .When I switch to 3d it shows the whole model building.
>So how can I go inside the room on first floor on 3d mode, do I have to make all the second level, floors,wall.columns etc "transparent"Seems
>a lot of work.So what is the proper proceedure to place crown moulding on each wall interior.In the tutorial, it shows only individual wall.Easy to place the crown moulding on the top of the wall.but on multi level building model,how to go on each room?dont know the proceedure.
>Edited by: bea09 on Dec 30, 2009 1:04 AM
