Revit Architecture
Active Contributor
rlabib
Message 1 of 3 (120 Views)
Phases question
120 Views, 2 Replies
01-24-2013 06:15 AM
I'm in the process of creating a new template for our office , so far we used the Architectural Template that come with Revit. And I like that has only two phases (New and Existing) . However I opened the construction template that comes with revit and I found at least 6 phase setup. And I would appreciate it if someone of experts here tells me what is the best way to handle phases? How many phases should I setup. We do a lot of renovation projects , so we always have existing and new elements.
Thanks in advance
*Expert Elite*
Alfredo_Medina
Message 2 of 3 (94 Views)
Re: Phases question
01-25-2013 12:32 PM in reply to: rlabib
rlabib wrote:
How many phases should I setup. ...
That question is really for your own office. It depends on the kind of work that your office does. That will give you an idea about the phases you need for your template.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Employee
loboarch
Message 3 of 3 (89 Views)
Re: Phases question
01-25-2013 12:48 PM in reply to: rlabib
You can take a look at this wikihelp article for some additional phasing explination and an example project showing the setup.
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Example_Project_to_Illustrate_Phasing
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
