Revit Architecture
Active Contributor
twilks1
Message 1 of 2 (269 Views)
Accepted Solution
Phase view control of shafts
269 Views, 1 Replies
12-05-2012 10:00 AM
I have a model with 15 floors and shaft objects in them. No matter what the Phase setting is for the shaft object the floor holes created by the shaft always show and cannot be eliminated with any Phase filter vew control. We need to adjust shaft locations and would like to maintain the cutting by shaft object through all floors. Any work arounds or methods??
Product Support
alan.quinn
Message 2 of 2 (242 Views)
Re: Phase view control of shafts
12-10-2012 08:37 AM in reply to: twilks1
This is a known issue that development is working on. It will most likely need a code fix to address. In the meantime I suggest using Marking Regions with Invisible Lines to hide the shafts.
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
