I have a model with 15 floors and shaft objects in them. No matter what the Phase setting is for the shaft object the floor holes created by the shaft always show and cannot be eliminated with any Phase filter vew control. We need to adjust shaft locations and would like to maintain the cutting by shaft object through all floors. Any work arounds or methods??
Solved by RDAOU. Go to Solution.
This is a known issue that development is working on. It will most likely need a code fix to address. In the meantime I suggest using Marking Regions with Invisible Lines to hide the shafts.
Thanks for posting.
I just checked the internal case as its still open. More current version were mentioned but its not clear if/when this will be address.
Thanks for posting.
Any progress on this issue? Im remodeling a large existing building with a dozen new floor shafts and the work-around is the kind of tedious tasks revit is supposed to save us from.
It would be easier if you use a void cut family (floor or surface based) to open those shafts with. It phases better, is controlled better and scheduled better
We are now 4 years on from when this bug was first identified, and yet it remains unresolved (at least it does so in Revit 2016). Yes there are work-arounds but they are not solutions, as the shaft opening does not behave according to the underlying logic of the software.
3 of us have spent 20 minutes trying to figure out what was going on, with a large project where a shaft opening had been wrongly allocated to a future phase by an ex-employee.
ToanDN,
You are missing the point. When the program does not behave in accordance with its underlying logic, you have to troubleshoot to find out why, particularly where you can't use the project browser to select the element in question.
None of us knew that there was a shaft in a future phase. It should not have been there, as the stair shaft it was meant to be forming was in the current phase, and other staff had drawn floors with the boundary creating the stair shaft. I myself was unaware there was a future phase in the model.
We can learn from the experience and ensure it doesn't happen again (saving 20 minutes x 3 people), but because we did not know it was a phasing issue even a search on the internet did to come up with the solution, because we didn't put 'phase' as one of the search terms.
The frustration is that some things in the program don't fully work, are known not to fully work by Autodesk, and don't seem to get resolved. Their limitations are not spelt out in the online help - in this case that shafts cut slabs of all phases regardless of which phase they are in, which means it is unhelpful to have them allocated to a phase in the first place.
andrewharle8552 wrote:
ToanDN,
Revit is only a tool (it is not 100% perfect; no Software or platform I have used so far is); however, how it is used is up to the user. For that reason some of us employ strict Guidelines and Best Practices on what a user MAY and SHALL not do. When a user goes rouge and does whatever, one can't blame the Software that it is not behaving with its underlying logic! At least...not on this one
How would you know!!!
Any other user might or can also place elements here and there mix up worksets, Phase to his liking, bloat your central with exploded CADs and the list is infinite when it come to how to mess up a model User vs Software. Who is to be blamed for that? Not the Software for sure. I would blame that on bad practice and unqualified Team members (if not Team leaders)
Troubleshooting is inevitable (applies to all Software) If it is done regularly and periodically one can avoid 90% of the mess. Revit gives and error (minor or major – regardless) and the users ignore. When that happens (for instance) one shouldn’t whine and complain after 6 months into the program that Revit is not behaving as one would want it to..
Revit, like many other leading BIM platforms provide tools with which one may do one things in a multitude of ways… they didn’t stop there; they even gave us access to Revit’s API and provided powerful tools such as Dynamo as well as interoperability with a multitude of software. It is the user who frustrates himself by limiting his options as well as his knowledge. Frankly speaking, the options provided by Autodesk Revit are close to limitless and when one tool doesn’t work the way one wants or expects it to doesn’t mean that such tools do not fully function the way they should… Many tools are also not meant to be used the way the user wants them to.
Back to the case of the shafts phasing…When one wants to phase horiyontally, one should not place or span vertical element unless those elements are phased separately...example a towers Core has it’s own phasing independent from the floors...it is a strategy which should be set before the Project Begins - how to split and how to Phase (One also can't blame an ex employee who did something to his own logic due to the lack of clear guidelines)…Therefore, when one wants to phase shaft openings by floor/slab then he uses/place X shafts (by tool) instead of one which spans from bottom to top…Personally I would still use a Void Family (for a dozen of other resons) … Same applies to almost every element one wants/plans to Phase
Unsubscribing to post ... apologies for not being able to entertain future replies to this thread but comments to PM inbox are always welcomed
The shaft tool should work and revit should have fixed this problem by now. A complicated and confusing workaround is not a solution.
@RDAOU: My question is why a shaft can not be phased while doors could be.
I'm stuck in some renovation projects when try to create a new shaft on the existing wall. But we create a new door, Revit understand that that wall need to be demolished a void for that door. Why Revit programmers didn't do the same with a shaft?
I agree that software just be tools. But if they can be better, why not? Many inventions, innovations start from stupid questions.
It is now September 2019 and this problem still appears to be here. Can anyone from Autodesk please either fix the issue; or tell us why it is impossible to fix; or say they hear us and just don't care.
P.S. the same problem also occurs for wall, vertical, face, and dormer openings.
@alan.quinn Is there some news regarding this issue?
Is it not possible to do for shafts what is possible for Voids?
