Regarding a building footprint that is long from south to north and then about 2/3s (two thirds) of the length the footprints turns 45 degrees to the left (making this angle the 135 degree angle of AutoCAD), then I want to create a long Building Section parallel to the building footprint with the bottom 2/3 of the section from south to north and then the last 1/3 of that building section turned 45 degrees to agree with the 1/3 angle of that part of the building.
Is this possible in Revit?
Thanks in advance.
Solved by octavio2. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
steps in order to acheive my workaround:
Constantin Stroescu
Thanks for your suggestion, Constantin.
I am still working with the two views and they are already satisfactorily put together, and I am cleaning what I want to see on each of the views and making the section good.
Your advice worked.
The only little problem that I have now is that as I activate each view for the cleanings and hidings, etc, I keep moving the views, desaligning them or making them bigger, etc. I turned off the crop region, and I think that might help, but let me ask, once that you determine that the views are aligned and once you like the way they are, is there is way to "lock" them in place so they would not move or desalign?
Thanks again.
