Parapet Interior wall finish above roof line
1 REPLY 1
vitus56
758 Views, 1 Reply
I have  an exterior wall with plaster and lathe on the exterior, and gyp board on the inside.  When I edit the wall structure, and modify the layers so that I can take the interior wall finish only up to the sheathing line, the wall does not join at the corners properly.  It leaves a gap for the interior fininsh at a corner above the sheathing line when looking in 3d.  Any suggestions?  What are you all doing with parpet walls and the interior finishes above the roof line?
1 REPLY 1
alan.quinn
in reply to: vitus56
I have two suggestions. 1. Create a second wall type for above the parapet or 2. Use masking regions to hide the what you dont want to see above the parapet.
Thanks for posting.
