Revit Architecture
Active Member
hans409
Message 1 of 2 (219 Views)
Parametric Array Family Trouble with Lenth Parameter
219 Views, 1 Replies
12-13-2013 07:45 AM
I'm having trouble with the length parameter in the attached family.  The object I'm trying to array will not stay constraited and is oddly affected by changing the length parameter.  When I set the array parameter then go to change the length parameter I get an error that the constraits must be removed.  If I remove the constraits and continue to change the length parameter the items do not stay centered.
Any ideas?
Active Member
hans409
Message 2 of 2 (208 Views)
Re: Parametric Array Family Trouble with Lenth Parameter
12-13-2013 08:23 AM in reply to: hans409
this post by fixed the problem, his suggestion to associate the parameters of the nested family fixed the problem.  AWESOME!
http://forums.autodesk.com/t5/Revit-MEP/Parametric-Family-floor-grating/m-p/4362607#M20066
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
