Revit Architecture
Revit Architecture
Active Member
hans409
Message 1 of 2 (256 Views)
Parametric Array Family Trouble with Lenth Parameter
256 Views, 1 Replies
12-13-2013 07:45 AM
I'm having trouble with the length parameter in the attached family.  The object I'm trying to array will not stay constraited and is oddly affected by changing the length parameter.  When I set the array parameter then go to change the length parameter I get an error that the constraits must be removed.  If I remove the constraits and continue to change the length parameter the items do not stay centered.
Any ideas?
Active Member
hans409
Message 2 of 2 (245 Views)
Re: Parametric Array Family Trouble with Lenth Parameter
12-13-2013 08:23 AM in reply to: hans409
this post by fixed the problem, his suggestion to associate the parameters of the nested family fixed the problem.  AWESOME!
http://forums.autodesk.com/t5/Revit-MEP/Parametric-Family-floor-grating/m-p/4362607#M20066
