Working up a door, i swear I'm going nuts.
I have set 2 parameters in the Family Editor so they 'Group Under' Dimensions, yet when I load into a project (that the family object has been deleted out of via the Project Browser), I find instead they are Grouped under 'Other'.
One of the offending objects attached.
Any suggestions as to why this might be happening?
I've done this 2 ways, once by opening within Revit the Family Editor, making the change and then loading back into the file, only to find nothing has changed, and also then by again opening up in the family editor from Revit to find ditto; and separately by opening up the file directly in Explorer and then loading into the open project.
Not an enormous problem, just annoying as I want to group Dimensions parameters naturally enough under Dimensions!
Solved by nmysorewala. Go to Solution.
Yes, on inspection is seems the 2 parameters, FrameWidth and FrameDepth, were set as shared parameters.
They were there as part of the 'Out of the Box' content, not created by me, so I wasn't aware of them being shared.
A quick export out with some reconfiguring and then imported to the project, and now fixed.
