Revit Architecture
Distinguished Contributor
jz4all
Message 1 of 5 (505 Views)
Paint color gray in (Realistic and Ray trace mode)?
505 Views, 4 Replies
03-04-2013 04:20 AM
I tried to create new materials to use them as a paint. But when I use these materials, they take the color I chose in (shaded mode) but they take gray color in ( Realistic and Ray Trace mode). Moreover when I creat these materials, in the ( Material Editor) if I select (Use Render Appearance) the color changes to gray without possibility to change it (just like locked).
Note: not all materials behave like that, some of them behave normal, in the meaning that the color I choose appears in all modes.
What is the reason? And how can I solve that?
Jaf
Valued Mentor
AJA14
Message 2 of 5 (495 Views)
Re: Paint color gray in (Realistic and Ray trace mode)?
03-04-2013 05:23 AM in reply to: jz4all
Hi. the "use render appearance" overrides the color you include for shaded and as such will revert to the gray color you are talking about. With regards to the rendering color, it depends on the loaded asset so when you decide to change the color or image be careful that you are changing the appearance asset itself which will affect any material with the same appearance asset. However, if you could provide an image, then maybe I can help with the existing problem.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
jz4all
Message 3 of 5 (485 Views)
03-04-2013 06:42 AM in reply to: AJA14
Thanks for your response.
Here are images as an example.
Jaf
Product Support
Chris.Aquino
Message 4 of 5 (426 Views)
03-14-2013 10:03 AM in reply to: jz4all
To give us better idea of what is happening, please strip the file down to that one magenta wall, and post it to the thread.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
jz4all
Message 5 of 5 (373 Views)
03-21-2013 06:25 AM in reply to: Chris.Aquino
Thank You for your response,
I solved it. I found een PDF about the subject and it explained me all details to understand the appearance of the graphics.
And to whom who faces the same issue , I mention here the subject to download it, (Interior Design Using Autodesk Revit Architecture 2013).
Jaf
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
