'loboarch' has a very inspiring video on WikiHelp which explains how to create very convincing 'Dusk Renderings', see:
I tried this and despite my efforts being not quite as good as that produced in the video I was pleased with the result, as follows:
This is a cropped image created from a 'prt sc' of a Revit sheet view on which I had superimposed the png image over the jpg, having followed the instructions in the video. However, when I came to export the project to dwfx, the jpg file (the sky) disappeared leaving only the png image as shown herewith:
Can this result be explained by anyone please? Can I not paste one over the other within the Revit environment, and get the expected result perhaps? Can the complete image only be achieved in a picture editing program?
I would be very interested to know.
Solved by IMCornish. Go to Solution.
I watched the video and the presenter did not mention export to dwfx. I'm assuming you what to export the project and have the image remain intact as it is in Revit. Perhaps anther approach would be to export the two images to photo editing application, do any necessary tweaking, insert back into Revit and then export to dwfx.
Hope this helps and thanks for posting.
I have no idea why or even if exporting to dwxf caused the issue but I had already got around it by doing as you suggested and I had thought of trying. that is I combined the two as as a single jpg in Adobe Photoshop and it worked. Just seems to me that exporting to dwxf should not do this.
