Revit Architecture
Valued Contributor
kwihae
Message 1 of 3 (623 Views)
Overlapping walls
623 Views, 2 Replies
12-22-2011 04:23 AM
Hello
Is there a way to draw as showen in the attachement?
The gyp wall needs to continue to the window panel element.
LisaDrago
Message 2 of 3 (617 Views)
Re: Overlapping walls
12-22-2011 05:00 AM in reply to: kwihae
Yes - you can do this...
You need to select the wall in an elevation and edit the profile of the wall. Reset the boundary to where you want the wall to go and finish the wall.
I have added images below to help.
LD
Don't forget to accept as solution if this worked!
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Employee
loboarch
Message 3 of 3 (605 Views)
12-22-2011 05:12 AM in reply to: kwihae
Here is the section in the wikihelp on editing the profile of a wall if you need some additional information on top of Lisa's post.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
