Overlapping walls
2 REPLIES 2
2557 Views, 2 Replies
Overlapping walls
Hello
Is there a way to draw as showen in the attachement?
The gyp wall needs to continue to the window panel element.
2 REPLIES 2
LisaDrago
Yes - you can do this...
You need to select the wall in an elevation and edit the profile of the wall. Reset the boundary to where you want the wall to go and finish the wall.
I have added images below to help.
LD
Don't forget to accept as solution if this worked!
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
loboarch
Here is the section in the wikihelp on editing the profile of a wall if you need some additional information on top of Lisa's post.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
