Orbit on middle mouse button
4 REPLIES 4
sbohlman
2401 Views, 4 Replies
I need to be able to work back and forth with sketchup, and revit. Unfortunatly the orbit and pan commands in revit are the exact opposite of sketchup( mmb = pan in revit) (mmb = orbit in sketchup) (shift + mmb = orbit in revit) (shift + mmb = pan in sketch up)
these commands are ingrained in my muscule memory and going back and forth is like writing one sentnce with your left hand and the next with your right. it is totally dibilitating.
Is there any way to customize these in revit? Can i change the MMB to be orbit and shift+MMB to be pan ?
4 REPLIES 4
LisaDrago
in reply to: sbohlman
Hello and Welcome to the Disussion!
Currently - not that I know of...
I know on some logitech mice, in the setpoint controls you can assign certain functions to the different mouse buttons.
Otherwise - unfortunately no.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Revisiting this question in 2019 - does anyone have an update on this, or do the same conditions apply?
...and as a side question, what IS the best forum for making suggestions and voting on ideas, etc?
Thanks!
RobDraw
Why dig up such an old thread instead of starting a new one?
AFAIK, this cannot be changed within Revit.
Rob
DarrenP
the idea station is here: https://forums.autodesk.com/t5/revit-ideas/idb-p/302
DarrenP
