Opening files?
2 REPLIES 2
Manish
117 Views, 2 Replies
Opening files?
A single Revit File while exporting to AutoCAD makes several files. Is there a way how we can customize the name of every created DWG file?
Help
2 REPLIES 2
in reply to: Manish
...only within the limits of naming the revit views and files. "Manish" wrote in message news:1300160.1100612974250.JavaMail.jive@jiveforum2.autodesk.com... > Hello, > > A single Revit File while exporting to AutoCAD makes several files. Is there a way how we can customize the name of every created DWG file? > > Help
in reply to: Manish
A single 'sheet" exported in Revit wikll export multiple files, one for the xref, one for the titleblock, and one for the whole drawing, with xrefs, etc. You can export by view, which will only export the individual view at a time, and then you can call them whatever you'd like. "Manish" wrote in message news:1300160.1100612974250.JavaMail.jive@jiveforum2.autodesk.com... > Hello, > > A single Revit File while exporting to AutoCAD makes several files. Is there a way how we can customize the name of every created DWG file? > > Help
