I do it modifying the window/door family, replacing the hole with void mass
But in revit help, this option appears to solve the insertion of door/window in a wall. But I don´t locate how to adjust the layers to locate opening insertion in walls, like can see in the help image. The help text is not clear on the process.
Any idea?
Solved by arqyt. Go to Solution.
Ok, I've solved the dilemma and share it.
Changing the cut-hole wall, for a void-mass, the enveloping layers fit this profile determined by this void-mass.
Accompany another image.
Regards
