Revit Architecture
New Member
cjohnson
Message 1 of 2 (126 Views)
Opening Model - Workset options
126 Views, 1 Replies
09-11-2013 07:05 AM
Greetings,
We have a central model that has several worksets and links.  When we open the model all the workesets are closed.  So I close the model, open the model with the open options and select All.  The model opens with all the worksets open.  I tried to save the model locally and centrall but the next time I go into the model the worksets are closed.  I would like all the worksets to be open by default.  Can anyone shed any light on why this might be happening?
This is for Revit 2014 (BDS) Build 20130709_2115(x64) UR1
Craig
LisaDrago
Message 2 of 2 (95 Views)
Re: Opening Model - Workset options
09-11-2013 11:36 AM in reply to: cjohnson
Hello and Welcome to the Discussion!
It sounds like an interesting issue - I was unable to recreate it.
I created a central model, closed all of the created worksheets and as I saved it I went to the options (image attached) and set the Open worksets default: to last Viewed.
When I opened the model all of the worksheets were closed.
I opened them all and sync'd to the central, then closed and reopened - but the worksheets were open. How they are kept at close I am not sure.
Even after opening them with them closed - have you gone to the collaborate tab or the worksharing shortcut on the status bar and just open them? Instead of closing and opening and specifying what is open? Just a thought...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
