add these in Settings>Options>File Locations. Under the Libraries area at
the bottom you can add paths. I hope to get drap and drop to this area in
the future.
Tip; Create your own folder of Shortcuts, and then put a path to this
shortcuts folder in the location above. Then in Revit, clicking the button
opens to your shortcuts, and clicking on the shortcut takes you to that
location within the Open/Save dialog box.
wrote in message news:5475890@discussion.autodesk.com...
In Autocad and ADT, the area on the left side of the open file box you can
add shortcuts to folders. Is there a way to do this with Revit? I've tried
to drag and drop like in Autocad, and I get the lined out circle.
